Sean-bumble-bee
Flight distance : 15997 ft
You probably can not. RPM are recorded in the DAT flight logs and it is likely that both DAT's are encrypted.
To check this download and instal CsvView
https://datfile.net/CsvView/downloads.html
and try processing the DAT from the screen device.
Do not bother with the DAT from the drone, that is even more likely to be enctrypted than the DAT from the screen device.
The txt flight log DOES NOT record motor RPM but it does record battery amperage, you might be able to deduce something from that but you would need to investigate the correlation between rpm and current for these type of motors.
The only FLY app using drones that I know of that create readable DATs are the Mavic Mini, Mini 3 Pro and perhaps the FPV.
If it is just general interest then I guess the Mini 2 SE has similar rpm to the Mavic Mini. From memory a Mavic mini hovers at around or slight 10,000rpm, I might have seen peaks around 16,000rpm but they would be rare. I am more confident I have seen peaks of 14,000rpm.
You might be able to read rpm with an optical instrument that was aimed at one propeller. If that requires a reflective surface on the propeller I would suggest you put equal amounts of reflective material of both blades of the studied propeller, IN IDENTICAL PLACES, at these rpm the centrifugal accelerations are significant and balancing is important.
