BreLouDro
Alright guys,
I am having a tough time with my T40/RC Plus controller.
I am trying to import shapefiles or kml files as field boundaries. Some of the fields I will be spraying are quite complex, with tree lines, waterways, creaks, ditches, etc. I exported field boundaries out as kml files, and converted them to Shapefiles. I loaded the files into a ShapeFile folder inside a DJI folder on an usb drive. Once I plug the usb drive into the controller, an import menu for field boundaries pops up. I select import as fields, it processes. then says import successful... now when I go to the fields and look for any of these they are nowhere to be found, on the map or the drop down menu. I feel like I am following the correct workflow, and I have to be so close, but I must be missing something, but I cannot figure it out. any help appreciated, Thanks.
