DJI Gamora
Kevin E Posted at 7-11 06:04
Hello. Thanks but the problem seems to be with the RC1 controller. Did you mean for me to return the drone or the RC controller? I also assume it is still under warranty, as it is only 4 months old.
Kevin
Hi, Kevin. As mentioned above, the warranty service can be claimed depending on the result of the Damage Assessment. You might want to check and try the steps from this thread as well. If it needs service, you're only required to send the RC. Hope this helps.
