JJB*
Flight distance : 12686732 ft
Fozflies147 Posted at 7-12 19:45
I got the Mini 3 with the RC controller. There wasn’t any error messages on the display and the drone had 31 sats locked.
If I stand directly behind the drone and point it forward, it sits off to the right of the rc icon on the screen and shows 180 degrees the opposite direction of the way it’s actually pointed.
Hi,
What do you see if you look in the map view, wich heading shows the blue arrow ?
Map view selected bu default North on Top, so easy to check if heading drone (blue arrow) is the same as the actual heading of your drone.So this view uses only the drone compass
In the compass mode the position of your drone (plus heading arrow = drone compass) is plotted into the 360, wich gets its info from the RC compass.
cheers
JJB
