DroneApe
Flight distance : 459954 ft
baronkaz Posted at 7-20 04:27
i am lucky coreboard is ok, thats for sure. i've downgraded mini 2 fw to 01.06.0200, turned phone in fly mode, and tried to enable fcc through controller bottom port. tried to fly 2km away on 50m height, signal was full all the time. only when i descended to 30m signal has lost two dots, but after i ascended back to 50m, signal was full again. and the whole flight never lost a signal
If the problem resurfaces, you can use the map below to see if you can find a correlation. If there was movement of NATO forces, there almost certainly would have been RF jamming equipment involved. June and July were fairly busy for testing in Lithuania and Latvia.
The map is for GPS, but drone jamming equipment can use many frequencies and modern, sophisticated drone jamming equipment can isolate the necessary frequency to send you RTH or splash your drone at their discretion.
Lithuania doesn’t seem to use (test) their equipment every day and it’s probably not on 24/7…only when needed for testing.
https://gpsjam.org/?lat=54.24687 ... amp;date=2023-06-18 |
