DanielWallet
China
To enable the Attitude (ATTI) Mode on your DJI Mini 3 Pro, you usually have to experience a loss of GPS signal, as ATTI Mode isn't a mode that you can manually switch to on most DJI drones; it's a failsafe mode. However, the DJI Mini 3 Pro doesn't officially support a manual switch to ATTI Mode. This mode is typically used when the GPS signal is weak or unavailable, and the drone needs to maintain flight stability without GPS assistance. In normal conditions, your drone should automatically switch to ATTI Mode if it detects that the GPS signal is too weak to provide stable flight conditions.
Please note that flying in ATTI Mode requires more skill as the drone will not hold its position automatically and can drift with the wind. It's also important to mention that the user manual does not explicitly detail how to enable ATTI Mode, which suggests that it is not a feature intended for regular user activation. For safety and compliance with local regulations, always ensure that your drone is within your line of sight and under control, especially if flying without GPS stabilization.
The information provided in the reference materials does not include details on how to enable ATTI Mode for the DJI Mini 3 Pro, focusing instead on features like the camera sensor, APAS 4.0, flight time, transmission distance, and smart features like FocusTrack and QuickTransfer.
If you're looking to adjust manual settings such as shutter speed and ISO for video recording, the M mode (Manual mode) on the DJI Mini 3 Pro allows you to do so. Remember to consult the drone's user manual or DJI support for further guidance on using M mode and other advanced features.
