The Saint
Flight distance : 5902228 ft
FeralUrchin Posted at 8-8 10:20
We disagree on "entitlement". The FAA exemption from registration and RID for flying recreational-only a sub-250g drone entitles me to fly my Mini 2 for recreational purposes now and into the future as long as the exemption is in force. But will future DJI software/firmware allow me to do so?
Now, apply the logic in DJI Mindy's post above, and note especially the "to the maximum extent" section. This seems to imply that, post 9/16/2023, since DJI software/firmware will be unable to determine whether my flight is recreational or non-recreational, and applying DJI's "maximum extent" strategy, I will be unable to take off post-9/16/23 due to "RID error" because my Mini 2 has no RID capability. I refer to this phenomenon as "bricking" my Mini 2. I think my use of the terms "entitlement" and "brick" should now be clear, so let's not debate my use of them. The question is simple: will DJI continue to allow me to fly my Mini 2 post- 9/16/2023 or not? DJI Mindy suggests "no".
Yeah that could be part of the problem. Your usage of certain words is far different than mine. Think of it this way: The FAA has said to the consumer only (not the manufacturer) that if your drone is less than 250g AND you use it strictly for fun or recreational purposes, the FAA does not require you to register your drone/RID details on the FAA portal. To me, that's like giving a pass on registration. It doesn't bestow any new rights or privileges or entitlements to the recreational pilots and if you look at it that way, no wonder you want to take your "rights" and go to the public and the manufacturers and says "look at what the FAA has given me, why are you infringing on me or taking away from me rights given by the FAA?"
One of the FAA rules given to the manufacturer is if you put standard RID in your drone, you must prevent the drone from taking off unless RID is activated and RID cannot be deactivated. To me, this in no way detracts or conflicts with the FAA telling you (the recreational pilot) the conditions in which they will not legally force you to *register.* When a manufacturer puts RID in a drone that you could have otherwise legally bypassed registration, as a responsible adult and a knowledgable consumer, you have the burden to see it for what it is and either move on to a different drone that is more suitable for your needs or recognize the fact that you still don't have to *register* (as the FAA has told you) but your RID details will still be transmitted (as the manufacturer has told you and as the FAA never told you they wouldn't be). In America, the consumer has choices; instead of complaining, take what you are given and make the call for yourself understanding that it doesn't work out for everyone the same. DJI has chosen the correct path for itself as well as what they believe is most suitable for their customer base as well as their future customers. For sure, they have met the FAA requirement and have received a Declaration of Compliance.
Short answer is No. Your Mini 2 will not be "grounded." Not sure why you would think so, I can only guess that you believe DJI doesn't see things the way you see it, you feel they made the wrong decision, they don't offer you a suitable upgrade path, and you disagree with the direction their company is headed. So you take the extra step and you try to label them with something derogatory like "bricking" a drone which is irresponsible and unprecedented and never implied. The Mini 2 drone doesn't care whether you fly it recreational or commercial, when you fly it (after you have been told it is not standard RID), the burden is on the pilot to fly legally. The FAA has told you (if you are listening) that you may have to add a broadcast module to your Mini 2 or fly in a FRIA. Figure it out yourself or ask here if you need further guidance. DJI has already told you "probably not" for RID but honestly, they don't own you a solid answer to their future plans; no promises. For all they know, you work at "Autel" and you are trying to figure out if their future sub 250g drones should have RID or not.
There is no "maximum extent" strategy and if you don't see a Mini 2 RID error today, there will be no Mini 2 RID error tomorrow. At this point, given DJI plans to take no action on Mini 2 with respect to RID, I translate that to mean we don't care what you do with your Mini 2 after the deadline, it's up to you, and we don't "continue to allow" anyone to fly or not. If you take off on a commercial mission or with a heavy battery in your Mini 2 outside a FRIA and you don't transmit RID, that's your issue, between you and the FAA....not DJI.
As far as I know the Mini 2 is no longer manufactured. One day it will be end of life and eventually, there will never be another Mini 2 flying in the FAA airspace ever again. At that point, depending on your individual needs, it is absolutely possible you may never fly another DJI drone ever again. Because DJI may or may not introduce a sub-250g drone without RID and it is super unlikely they would ever introduce a standard RID drone that can be RID disabled. DJI is not in the business of extending a particular drone model indefinitely. Instead, the Mini category will likely evolve. And it will likely include full time RID. At that point, those who are strictly looking to "qualify for the exemption" will likely be lost and like a smart consumer, will take their business elsewhere if necessary. Because looking to fly a DJI Mini drone that doesn't transmit RID so you can "qualify as an exemption" just isn't a thing. |
