HermosaDrones
Flight distance : 3160344 ft
DJI Tony Posted at 8-10 01:58
Hey there. Thank you for reaching out. The Air 3 uses the common USB-C interface for charging. You can directly use chargers with this type of interface such as those for Android phones, Macs,.etc to charge the Air 3. Please note:
1. When charging the battery with the battery mounted on the DJI Air 3 aircraft, if using a third-party charger, it is recommended to use a 65W fast charger that supports PD3.0 protocol.
2. When charging the battery using the DJI Air 3 battery charging hub, if using a third-party charger, it is recommended to use a 100W fast charger that supports PD3.0/PPS protocol.
Thnk you, both. I will order the DJI chargers when in stock again, juts want a shprt term solution so i can fly. |
