djiuser_nkHfojS8H9tj
Flight distance : 2587211 ft
So I'm having a ton of issues with my new-to-me DJI FPV drone. I purchased the drone a few days ago and the drone was working perfectly fine for the first few days as far as I could tell. It was barely flown, under 2 hours of flight time, no scratches or accidents, and not a single sign of wear on either sets of propellors. I had noticed one weird quirk right away, that being that I cannot force the drone to go into pairing mode by pressing and holding the power button until just after and within a few seconds of the aircraft's fan from turning on. I cannot do it before then, and if I wait too long, I'm unable to again. This is a pain considering the fan doesn't always kick on until the drone is warm enough to need the fan. Secondly, also relating to linking, the controller CONSTANTLY disconnects. This issue had only started happening a few days after owning the drone, with no event occurring before then. No crashes or incidents, it just started happening randomly. Each time I turn on all the components, it is a toss-up on whether or not the controller will link, or if I will need to force the aircraft to link (again, annoying because of the fan quirk). Once I finally do get the controller connected, it either immediately disconnects again after about 5-10 seconds, or I am able to take off and fly for a moment and at about 100-300 FEET the controller disconnects and the drone flies home. It doesn't reconnect when it gets close again either, since the controller's four lights start flashing indicating it isn't even paired to the drone at all anymore, so there is nothing I can do until the drone lands on its own. This is soooooo frustrating and scary when flying when the screen goes black nearly immediately. Why is this happening to me!?
