CC-Mapper
Todays flight was far to long to record. I will do a short mock up run Monday and record it.
As far as today, here is how it went:
Oblique 5 leg lidar mission. Batteries low enough after the 4th leg (18% and orange in the App) that I Pressed pause in the APP itself(which I theoretically did not have to do and maybe part of the problem, as RTH from the controller button will pause the mission), then RTHed the drone. Hot swapped batteries, making sure to wait at least 10 seconds between each (spec is 3 seconds), then pressed the Play button and was not offered an option to Resume. All 5 legs were listed and blue with the bottom of the dialog saying Start, which I had to deselect 1-4 and just do the 5th. I haven't processed the data yet, hoping it was ok.
If you can think of any errors with what I have done from the above, please let me know, will get video asap. I haven't recorded UI video yet, hope its in the manual!
Thanks guys, will let you know. |
