Hi there. We're sorry for the trouble that this has caused. Can you please confirm if the gimbal tilt to 90 degrees are working using the gimbal dial on the remote controller? Please provide us a screen recording showing the issue after you set the C1 button to recenter/tilt down the gimbal. Furthermore, please confirm if the C1 button works on different function when you set it? Please keep us posted. Thank you.
DJI Paladin Posted at 8-24 18:59
Hi. Thanks for responding.
The gimbal tilt works all the way up and down with the left dial just fine.
C2 button works to toggle Landscape/Portrait or Camera Settings or Recenter/Tilt Down Gimbal
C1 button doesn't work with any selection.
Which screen shot do you need?
Louis Riel Posted at 8-24 20:10
Thank you for your response and we're sorry for the unpleasant experience. I'm afraid that you may consider sending the RC in for proper diagnostics. You may contact our support team at https://www.dji.com/support to see the possible option for you to send the unit to us. Thank you for your understanding.
DJI Paladin Posted at 8-26 02:47
Thanks. I had a feeling it was headed that way. Further investigation reveals the C1 button does not function with any of the menu choices all of which work fine with the C2 button. I've started another thread with that line. https://forum.dji.com/forum.php? ... 6orderby%3Ddateline
Louis Riel Posted at 8-26 13:24
Thanks. I had a feeling it was headed that way. Further investigation reveals the C1 button does not function with any of the menu choices all of which work fine with the C2 button. I've started another thread with that line. https://forum.dji.com/forum.php?mod=viewthread&tid=296529&extra=page%3D1%26filter%3Dauthor%26orderby%3Ddateline%26typeid%3D776%26typeid%3D776%26orderby%3Ddateline
You're welcome. Please contact our support using the link above to process and send the unit to us for diagnostics. Should you have other inquiries, please don't hesitate to reach us. Thank you.
I have this issue with a bad c1 Button that came with a new air 3 with the Dji rc2. What sucks about sending it in is that it's going to take a while for shipping to/processing/shipping back.
