Labroides
Flight distance : 9991457 ft
Joe Dawson Posted at 8-28 04:18
I just did some testing on the bench and if I have a camera full tilt from the top position to the bottom position in using the 1X camera if that takes 11 sec. Doing the same thing with the 3X camera will be more like 25 sec. I don't know what the ratio is for yaw because I couldn't test that without being in the air but I assume it is another case where YAW is impacted by the lens you are using. I know this is the way it works now but I haven't seen this documented anywhere.
That's completely normal.
With the Mavic 3 pro with three cameras, it has three different yaw speeds.
Rotating the drone with the longest lens is the slowest. |
