Ingo2023
Depp Posted at 9-6 22:02
As for criticism: Good: circling; edit to the beat.
IMprove: If you change direction in the shot do it really smoothly. If you can't or if the change is jerky: cut the clip and put some other angle in-between, for example at the indecisive gimbal movement at 2.52.
All in all a decent start. I'd shorten the individual clips more, I normally use clips between 2 and 4 seconds unless the clip itself is dynamic in itself.
Thank you so much for embedding it. I will have to check into how to do that.
I appreciate your tips regarding the clip length etc. So much to learn, yet so exciting.
Thanks again. |
