phivestardave
Flight distance : 14281 ft
DJI Gamora Posted at 9-11 19:49
Hi, phivestardave. Thank you for reaching out. Please try to clean the screen with a clean dry glass towel and perform a factory reset (Enter Settings > System > Reset options > Erase all data(factory reset)). If the issue persists after that, please send the DJI RC back for further diagnostics. You may submit an online repair request through this link: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at (https://www.dji.com/support). We understand that this is not the answer that you look forward to, but this would be the best thing to do in this situation. In addition, warranty service can be claimed depending on the result of the Damage Assessment. Your kind understanding is appreciated and thank you for your continued support.
Thank you! I was able to do the factory reset and it removed the problem.
Just in case anyone else has this problem:
I noticed that if I pressed the power button quickly (to put the screen to sleep) and then opened the screen back up - there was a split second that the screen would respond to touch. I was able to swipe down from the top of the screen (very, very quickly) and then hit the settings icon. It took me a few times, but I eventually nailed it. Once in the settings, the touchscreen worked perfectly. Bizarre. I system reset that bad boy and it fixed it. Thanks for the help! |
