DJI AIR 3 & Freewell CPL Filter - Problem
2654 13 2023-9-13
StubbornSwiss
Flight distance : 480771 ft
Greetings!
I just received and tested the Freewell Circular Polarizer filter for my Air 3.
Unfortunately the drone recognizes this filter as a Wide Angle Lens, and disables some shooting functionality.
I understand from Freewell (as well as online posts) that there was a similar problem with the Mavic 3, which was resolved with a firmware update.
I would like to bring this to your attention, and hope there will be a resolution soon.
Many thanks.
2023-9-13
Hallmark007
Flight distance : 12400594 ft
I think it’s probably a weight issue , so the drone thinks its a wide angle instead of a normal filter.
2023-9-13
JodyB
Flight distance : 322005 ft
My thinking is like Hallmark's, its more than likely a weight issue. with the CPL making the air 3 think its a widw angle lens.
2023-9-13
StubbornSwiss
As stated by Freewell, this seems to be fixable with a firmware update.
See also the linked thread:
Error with FREEWELL filters
2nd to last post says it was resolved with an update.
Hopefully someone from DJI will be able to respond to this.
2023-9-13
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We will coordinate this to our relevant team for attention. We will keep you posted. Thank you.
2023-9-13
StubbornSwiss
DJI Paladin Posted at 9-13 21:57
Thank you.
2023-9-14
DJI Paladin
Thank you for patiently waiting. If you experience a prompt stating "Wide-angle lens attached" after you attached a polarized filter on your DJI Air 3, It is recommended that you need to first land the aircraft, and remove the propellers to check whether the gimbal is scratched, and whether the gimbal enters the normal stabilization state. If no error is identified after checking, it is recommended that you place the aircraft on a flat and clean ground and rotate the propellers again to check whether the issue occurs again. Thank you.
2023-9-16
StubbornSwiss
DJI Paladin Posted at 9-16 00:31
Thank you for your response.
I can confirm that gimbal is not scratched, and it enters full stabilization state on start up with CPL filter attached. However, the error continues.
Without the filter, everything is fine, no error.
2023-9-16
StubbornSwiss
Just did a flight with the CPL filter on, and everything seemed to work fine. No warnings, no errors....... I was able to select pano mode.
Will keep monitoring.
2023-9-16
DJI Paladin
StubbornSwiss Posted at 9-16 05:12
Thank you for the information provided. We will also coordinate this with our relevant team for attention. We appreciate your understanding and support.
2023-9-17
franceslup
Flight distance : 307602 ft
I received today the polar pro ND/PL filters and no problem at all.
2023-9-18
djiuser_EXP5WpCzetnL
Flight distance : 1198757 ft
I'm seeing the same error with my Air 3, tried the fix but to no avail. This is happening with Freewell filters and Newer filters too.
2024-1-26
Airpilot2
Another update and still no fix for this!
2024-2-9
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
Try putting on the filter with the drone turned off and on.
2024-2-10
