DJI Gamora
Hi, aerosw1ft. Thank you for reaching out. DJI Mini 3 Pro is designed without a built-in fan, which can effectively reduce power consumption to make the flight time longer. Additionally, the new structural design with propellers that have been adjusted for a more aerodynamic flight, allows the drone to use the wind generated by the propellers to dissipate heat, ensuring good heat dissipation effects during the flight. If the drone stays in standby mode for a long time, its temperature may continuously rise. DJI Mini 3 Pro comes with a built-in temperature control system that the drone can detect the current temperature and decide whether to automatically power off to prevent overheating.
The regular standby periods of DJI Mini 3 Pro in the stationary state are as follows (measured in an indoor environment with an ambient temperature of 25℃). If exceeding the standby time, the aircraft may automatically power off to prevent overheat.
During flight: The aircraft is not overheated.
When in standby mode on the ground: Approx. 22 mins.
When updating firmware: Approx. 19 mins (sufficient for 3 times of upgrades; 5 to 6 mins for each update).
Remarks: It should not damage the internal as long as you follow the prompts on the app. If the room temperature is high, or when the mobile phone’s fast transmission function is in use, the power consumption of the aircraft will increase, resulting in more serious heating, so the standby time will be shorter. It is recommended to refer to the aircraft’s prompts to shut down and cool down, or use other physical methods to reduce the temperature of the aircraft, such as fans or air conditioners.
If the aircraft is at room temperature within 5 minutes, it will prompt "Aircraft Overheated" and then automatically shut down. It is recommended that the user send it back for further diagnosis. |
