Hi,
installed the latest version today on my M30T.
On RTH (press button on DJI RC plus) the gimbal will rotate horizontal. When bringing gimbal down (shortcut on button or by wheel on Controller) then the gimbal will turn horizonatl again durning RTH.
Imaging the following situation:
Sun > drone rear facing sun > take off 50m height, gimbal down > fly 50m away > press RTH.
What happens:
drone turns 180 degrees, gimbal turns horizontal, sun is burning into the IR camera, drone fly to the homepoint, when reaching the homepoint, drone rotates back to take off direction, (rear to sun, so perfect), the gimbal goes down )), lands (gimbal goes horizontal at 2m height)
This will burn/damage the IR camera. Imaging RTH becaue of low battery or connection lost.
Hi, fansc880a5c0. Thank you for reaching out. Let me forward your concern to our relevant team for further checking. We'll let you know once we receive an update. Thank you.
Hi,
any news on this?
Have at least the developer responded with something like "we can reproduce it" and with "we are working on it to fix it"?
Or should i open a support ticket with DJI? What is the recommended way?
Gruesse
Daniel
