I don’t really have much in the way of an explanation - I’m quite perplexed. As I said in my previous post the pilot didn’t cause flying into the bushes via any MC2 inputs.
There is a discrepancy between east velocities. The GPS receiver determines the east velocity from the doppler effect on the received satellite signals. This data is then fused with several other data (accelerometer, gyro and magnetometer) to get a higher resolution east velocity that is then used for navigation. In this case the fused value is [0.0 – 0.2] m/s. The actual value from the GPS receiver is -3.3 m/s; i.e a 3.3 m/s west velocity. A westerly velocity is also confirmed by the video.
One possible explanation is that the FC thinks the Avata should be moving west instead of being stationary or have a small east velocity. To compensate a west thrust vector is commanded.
The mobile device .DAT is just too slow to see if this the case and the onboard .DAT is encrypted. Without the faster onboard .DAT it’s hard to know why the fused east velocity is incorrect. Since the fused value depends on accelerometer, gyro and magnetometer data an IMU and a compass calibration would be a good idea.
