DJI-Dave
Inspire1 Battery calibrating.
You need to calibrate smart batteries, if you do not you're asking for trouble. Even smart batteries for medical devices require calibration.
Not all packs will come back to 100% if its capacity has acuatly reduced, your calibrating may be spot on based on the packs voltage curve.
Sometimes packs with very low cycles can have a drop in capacity in the short term, this does not mean they will continue to drop, some just drop and settle there.
I would calibrate and then fly 20 flights with what ever the capacity comes back to then calibrate again.
It seems people are calibrating to try and recover capacity they may not have, perhaps the update now shows the true capacity whereas before it did not.
What it says is irrelevant all that maters is you have a stable pack with acurate remaining capacity, a few hundred mAh reduction in reality will not make any real difference in the real world. |
