The Matrice 300 RTK cannot be used for charging an external device.
This is, however, available through the SDK development.
The Matrice 300 RTK supports the PSDK gimbal power supply and the OSDK power supply using the Extended Power Port (XT30) (a Matrice 300 RTK OSDK Expansion Module is required.)
The PSDK port output voltage is 13.6 V or 17 V, and the maximum current is 4 A. (The default output voltage of the PSDK port is 13.6 V. If the user considers the power to be insufficient, use API to apply for a high power. At this point, the PSDK output voltage will be changed to 17 V.)
The constant voltage of the OSDK port output is 24 V, and the maximum current is 4 A. The combined power of the four SDK ports is limited to 180 W. |
