nicholas.goss
It would take
1) Retractable landing gears
2) A different gimbal
3) Sticks/buttons/wheels to control the camera left and right
If (2) is achievable, then it may be possible.
I have not connected a 2nd controller yet, so I'm not 100% sure if it will work the same way as the inspire.
With respect to number 3, I want to use head tracking so there should be no need for additoinal controls for the cameera as the gimbal will be moved with my head and a head tracker unit. Such as the trinity head tracker.
That may be a hint, that the camera can be linked to the transmitter sticks of a 2nd inspire remote.
Thats what I was hoping for, that because the camera DOES have the physical ability to pan, then one should only need the correct software or device to tell it to pan, such as a head tracker.
Even more important if I was to go ahead and buy retractable landing gear... but if you cannot pan the camera there is no point in getting the retractable landing gear
Like I said before I dont want to replace the camera as it was one of the main reasons I paid extra money to get the Pro over the advanced.
So taking it off to put on a less quality camera for head tracking makes no sense.
Also, I have read that the P3 Pro, has been made so that you cannot take the 4K camera off the gimbal, it's all one unit. So if you fit a new gimbal you would have to fit a new camera as well bot re-using the perfectly good DJi camera.
