DJI Gamora
Hi, Harper. Thank you for reaching out. There is no certain distance required, it is based on the subject. The aircraft tracks the subject in a circle based on the set radius and flight speed. Move the roll stick to circle the subject, pitch stick to alter the distance from the subject, throttle stick to change the altitude, and yaw stick to adjust the frame. Hopefully, other users can provide their insights as well. |
