DJI Paladin
Thank you for patiently waiting. The maximum height/altitude can only be set every 5m (multiple of 5), for example: 120m, 125m, 130m, 135m and so on, cannot be manually dragged and set to 121, 122, 123, 124m. The same explanation if you use the ff: the next height/altitude of 393ft (about 120m) is 410ft (about 125m), which cannot be set to 400ft. Hope this helps. Thank you for your valued support. |
