AerialLens
Hey, Barnard, what Paniza and others are saying is that it is extremely difficult to remove the lens cover the first time because the inward radial force from the outside toward the threads must be perfectly equal. That is, you just cannot "squish" in one direction across that circular object. For example, grasping across the cover with your thumb and forefinger actually serves to clamp the thing even tighter ! That is frustrating. So the rubber band idea serves to equalize that force all around.
Alternatively, the easiest way many have found is to apply pressure equally by using a flexible item like rubber or leather or soft plastic to engage the RIM all around FROM THE FRONT edge, THEN turn when there is enough friction. I know that sounds really confusing, so here is a diagram...
Of course, PLEASE be sure to hold the rear of the camera firmly in such a way as to prevent stress to the gimbal. Good luck. |
