jazzcat
Flight distance : 3129783 ft
South Korea
I received it the day before yesterday and hope it will be improved after a few days of use and inconvenience.
If firmware is supported, it would be great if it could be improved and updated.
1. When switching quick shots, the text is too small to verify the user setting number.
Can see it well? I can't see anything.
I hope you can see the letters "C1", "C2", and "Video"... next to the icon in the display window.
And the setting status under the icon is not spaced out, so you have to look closely to find out.
2.7k60p4:3 -> 2.7k 60p 4:3 Please space it like this.
2. There is an operating delay in actual use.
At first, it works immediately, but if use it a little, the reaction will appear late when you operate it.
There is a response delay that works after 2 to 3 seconds.
This phenomenon disappears when the power is shut down and restarted.
3. Can't extract recorded GPS data?
Personally, it would be better if this could be handled in a PC environment than in a mobile environment.
The MIMO app is not optimized for tablets, so it's a bit inconvenient to handle.
I'd like to be able to access it on the web or edit it with a separate PC app.
4. I think it would have been better if there was a horizontal direction where the band could be fastened.
Looking at the structure, it seems that the direction in which the band can be inserted is enough to make a hole so that it can be fastened horizontally.
It's a bit uncomfortable to look longitudinally when fastening to sticks or bicycle handle bar stem... It's a bit of a lot.
----- Korean Language Below
그저께 받아 며칠 사용후 개선되었으면 하는 점과 불편한 사항입니다.
펌웨어를 지원한다면 개선되어 업데이트를 할 수 있으면 좋겠습니다.
1. 퀵샷 전환시 글씨가 너무 작아 사용자 세팅 번호를 확인할 수가 없습니다.
잘 보이시나요? 저는 하나도 안보입니다.
표시창에 해당 아이콘과 함께 옆에 ‘C1’, “C2’ 등의 글자가 크게 잘 보였으면 합니다.
그리고 아이콘 밑 설정상태 띄어쓰기가 안되어 있어 자세히 들여다 봐야 알 수 있습니다.
2.7k60p4:3 -> 2.7k 60p 4:3 이렇게 띄어쓰기 좀 해 주세요.
2. 실제 사용시 작동 딜레이가 있습니다.
처음엔 즉시 잘 작동하는데 조금 사용하다 보면 조작시 반응이 늦게 나타납니다.
2~3초 후 작동하는 반응 지연이 있습니다. 전원을 종료후 재 시작하면 이런 현상은 없어집니다.
3. 기록된 GPS데이터를 추출할 수는 없습니까?
개인적으로는 이런 작업은 모바일 환경에서 보다는 PC환경에서 다루어질 수 있으면 더 좋을 것 같습니다.
MIMO앱이 태블릿에 최적화 되어있는 앱이 아니어서 다루기에 다소 불편합니다.
웹에서 접근할 수 있게 하거나 별도의 PC 앱으로 편집이 가능 할 수 있으면 좋겠습니다.
4. 밴드를 체결할 수 있는 뱡향이 가로방향도 있었으면 더 좋았을 것 같습니다.
구조를 보니 밴드를 넣을 수 있는 방향이 가로방향으로도 체결할 수 있도록 충분히 홀을 만들수 있을 것으로 보입니다.
스틱이나 자전거 핸들바 스템에 체결할 때 세로 방향으로 보이게 되어 다소 불편합니다. 많이 아쉬운 부분입니다.
펌웨어가 지원된다면 개선과 업데이트가 가능하면 좋을 것 같습니다.
