Monkey007
Flight distance : 73775046 ft
Dirty Bird Posted at 10-10 04:53
Reading the specs on this 3-port charger is confusing. The specifications state it only charges 2 of the 3 batteries at once. This requires a minimum 45 watt PD supply. There is also a 4-port version available for only pennies more. Again, the 4-port model charges only two of the four batteries simultaneously. Amazon offers a visually identical 3-port version that claims simultaneous charging of 3 batteries with a minimum 65 watt PD supply.
While I like the drop-in design of this charger, if going for something to simultaneously charge your flight batteries, I would go for the link below. While less elegant, it offers true simultaneous charging of 4 flight batteries, plus two USB-A ports (3 amp total) to charge your RC & phone.
A little confusing indeed, it took me quite a few minutes to read the specs too, before I chose the 3 port instead of the 4. The 3 port can charge 2 packs simultaneously at 3.5 amps, or 3 packs simultaneously at 2.5 amps; while the 4 port can only charge 2 packs simultaneously as a group, and charging in two groups sequentially. |
