djiuser_vB7rsMeLSR1z
Flight distance : 29892 ft
Interesting.
I purchased a GoPro to replace my OA1, and swapped it for an OA3 within 24 hours. I hated the GoPro. However, the OA3 ended up getting swapped for an OA4 because it didn't record half the time, and of that, only half of the time it would record sound.
But the OA 4 seems to have the same problem with the sound. My setup on the OA1 was Rode wireless go 2 connected by the analog Cyanova adapter and worked flawlessly. I'm wondering if NOT using the USB C mic input from the Rode receiver but getting the Boya USB C to 3.5mm analog adapter would be a better idea whilst this bug persists?
Additionally - I'm confused by TRS / TRRS. I have two microphones connected to the Wireless Go 2 RX, I use one for voice when riding and the other for ambient sounds. I have it set to split mode to record two separate channels so that I can mix in post. What cable would I need to connect the TX to the adapter with to do this, and is the Boya BY-K2 the adapter I need?
Thanks
