Cano R7 working with DJI raven eye
362 3 2023-10-21
Wayne za
South Africa
Good day allI would like to find out if it is possble to pair Canon R7 with Raveneye on the DJI RS 3 Pro.
I get is conneted BUT i can not get the live view on my Phone.
Any suggestion what is need is it a setting or is it not possible?
Thanks
2023-10-21
DJI Wanda
Hello, there. You may refer to the setup method in the link and tell us your feedback:
https://www.dji.com/support/compatibility/rs-3-pro/eosr7
2023-10-21
Wayne za
South Africa
DJI Wanda Posted at 10-21 03:36
Thanks tried this not working No live video on phone
2023-10-21
DJI Wanda
Wayne za Posted at 10-21 03:50
Thank you. Would you please perform the following troubleshooting steps and tell us:
1. Check whether the camera firmware meets requirements and whether it is the latest version.
2. Check whether the camera HDMI output is normal (testing method: Connect the camera to another display or monitor using an HDMI cable, and check whether the display or camera can output normally. Check whether the HDMI cable is functioning).
3. Check whether the HDMI video output source format set in the camera is supported by the RavenEye Image Transmission System.
4. Check whether the camera settings are correct (check “Notes” on the DJI Ronin RavenEye Image Transmission System Compatibility List.)
5.Check whether the camera resolution settings meet requirements (for Nikon cameras).
6. Check whether the mobile phone Wi-Fi has been enabled and is functioning (the Wi-Fi can be connected normally).
7. Check whether the Status LED of the RavenEye Image Transmission System is functioning (solid green).
8. When the RavenEye Image Transmission System is powered on, tap the Power button six times to cancel the password of the RavenEye Image Transmission System. Try connecting again.
9. In the mobile phone settings, select to forget the RavenEye Image Transmission System network on the WLAN interface. Enable the mobile phone WLAN again and go back to the Ronin app interface to connect.
10. Go to mobile phone system settings - App settings and check whether permission for the Ronin app has been enabled (The related permissions in positioning, Bluetooth, and WLAN must be enabled).
11. Use another mobile phone and try again.
2023-10-21
