Anonymous1
Flight distance : 602303 ft
Jamaica
Danergo Posted at 10-29 00:00
Hi, I'm rather confused now. What do you mean by "left in AUTO in DLOGM"?
I think the point of the color sensor is to change internal image processing parameters according to current lighting.
What I said, still remains. DJI needs to be more transparent in what that sensor really does. Yes, as the moderator said, the dynamic range is going to be somewhat improved. As answered the sensor is also used in the AUTO feature in DLogM.
What I was explaining is that if you are serious about manually color correcting the DLOG footage under changing lighting scenes such as moving from neon lighting indoors to broad daylight outdoors, then you would not want to use the AUTO feature, and actually set a manual white balance. Leaving it in Auto, results in wonky colors when trying to color correct the second scene if doing it from scratch.
If all you plan to do is apply DJI's published LUT (Look UP Table), then yes go ahead and leave it in Auto.
Based on your question, it seems you just want easy-to-edit footage, and don't care about color correcting or trying to match colors with another camera, I agree you should just leave it in Auto
