DJI Paladin
Hi there. Thank you for reaching out. The Cruise Control function enables the aircraft to lock the current control stick input of the remote controller when conditions permit. Fly at the speed corresponding to the current control stick input without continually using control stick movements, and also support more camera movements such as spiraling up by increasing the control stick input.
Notes:
1. Cruise Control supports more control stick movements such as ascending the aircraft when flying forward or ascending/descending the aircraft when flying around an object, etc.). If the Cruise Control button is pressed, the current control stick input of the remote controller is locked, and the aircraft can maintain the flight along with the current flight path.
2. When entering cruise control, only the reverse stick movement in the forward direction responds, and the aircraft will move at a lower speed. (For example: If the aircraft flies leftward, moving the stick rightward represents a reverse stick movement. If the aircraft flies forward, moving the stick backward also represents a reverse stick movement.) When other sticks are moved, the aircraft will not respond, and it will not exit cruise control mode. Hope this helps. Thank you for your valued support.
