RC Connection lost - Drone turns off - Video feed still there
424 4 2023-10-26
RichyDigitized
Flight distance : 39 ft
South Africa
Hi there,
Has anyone else had or are having this issue?
When I switch on my drone and RC and connect, everything connects ok, then after about ½ a minute or so the RC says , "RC not connected", and my drones goes off (the lights), but I can still see the video feed on my phone?
I've tried connecting to Assistant to update but the drone swtiches off again before I can finish the update, if it needs it.
Rather perlexed, I've looked after my Mini, never dropped or anything.
2023-10-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Please record a short video showing the issue using your mobile device then upload it to Google Drive and send the link here so we can further check the issue. Please keep us posted. Thank you for your cooperation.
2023-10-26
Sean-bumble-bee
Flight distance : 15997 ft
If you move the drone after it has "switched off"  can you see the movement in the image seen on your phone?
2023-10-26
RichyDigitized
South Africa
Sean-bumble-bee Posted at 10-26 23:25
Yes, there is still live video feed
2023-10-27
Sean-bumble-bee
After the drone switches off use the gimbal dial to try to tilt the gimbal down. Does the gimbal respond?
If so use the phone screen to try and drag the gimbal upwards, does the gimbal respond?
2023-10-27
