DJI Gamora
Hi, Tech-Retard. Thank you for reaching out. There is no way to adjust the zoom speed but you may zoom in and out with the wheel as well as the app to have a try. With the programmable flight modes, do you the waypoint function? If so, you can select Auto, Digital, or Manual.
Digital: Drag the bar to customize the zoom ratio.
Manual: You can manually adjust the zoom ratio during the flight.
If you mean to adjust the sensitivity of zoom, we will take this as a suggestion of yours and y, it is not supported. We will take it as a suggestion of yours and forward your concern to our related department. Thank you for your continued support. |
