DJI Tony
Hi there. Sorry about the trouble. Please try the procedures below and see if it will help;
1. Check whether DJI Pocket 3 has been attached to a smartphone adapter. If so, please try plugging the smartphone adapter in a reverse direction or connecting DJI Pocket 3 to a computer without using a smartphone adapter.
2. When Pocket 3 recognizes the computer, a prompt will appear on the touchscreen asking “connect to computer?”. Please select “Accept”.
3. If you are using a DJI USB Splitter Charging Cable (Type-A to Type-C), please connect the cable with the data transfer logo on the connector, if the other one is connected, it only supports charging.
4. Restart Pocket 3 and replace the USB-C cable, the port of the computer, and the SD card to have a try.
5. If a Mac computer with an M1 chip is being used, it is recommended to use a microSD card reader to copy photos and videos. If possible, please use another computer.
If the issue persists please send back the device for inspection. We appreciate your patience. |
