Arnie R
Flight distance : 80958 ft
Hoarfrost Posted at 11-4 21:06
Make sure that the cables you are using are DATA cables. I've had some data cables go bad and get the error message like you mention. Charging cables don't work and since there's no easy way to tell them apart, people often have issues.
USB 2 speed cables aren't good enough - you need USB 3 or better capable data cables.
Makes sense. What doesn't, though, is why the enclosed cable attached to the RC worked perfectly last week, however, it does not now. |
