Video shaky footage.
472 6 2023-11-10
djiuser_uD4ADFxIk0Oe
Flight distance : 330003 ft
India
The video is shaky while flying.
This was not an issue earlier. Started from some time. Please urgently help.
Attached the video in the drive link.
https://drive.google.com/drive/folders/1YAB1rPbQJRMfIowA8a7u-6tTdZszZqJi
2023-11-10
DAFlys
If this only happens when the props are spinning then you have damaged propellers.
2023-11-11
Louis Riel
Flight distance : 123563 ft
New Zealand
I had the same problem. Cracked gimbal arm. Superglue repaired OK.
https://forum.dji.com/forum.php?mod=viewthread&tid=298046
2023-11-11
India
Ok thanks, will definitely try it.
2023-11-11
Sam654
Flight distance : 132667 ft
The first video, it's on the ground shaking. Looking from the outside, do you see the whole thing shaking, or just the gimbal, or just one wonky prop or arm?
When stopped, check all props, motors, arm joints and the gimbal for anything loose or out of place.
2023-11-11
India
Sam654 Posted at 11-11 12:22
No. The gimbal was vibrating.
I saw there was a hairline crack in the gimble arm.
Have glued it and it works perfectly now.
2023-11-11
DJI Paladin
Flight distance : 318 ft
Hi there. According to India Import Policy, Drones are 'prohibited' except for R&D and defense use. There are no DJI Authorized Retail Stores in India to sell drones. Simple consultations are available but aftersales repair service cannot be provided. Hope for your understanding and patience.
2023-11-11
