Sam654
Flight distance : 132667 ft
In most cases the shutter speed will compensate for overexposure. But if like me, you find a super fast shutter a bit jarring when there is a lot of motion, usually when near the ground, then ND filters alow you to slow that shutter down for smoother motion.
But if you don't mind a fast shutter, you can probably get way without them, it's a case of suck it and see. There is nothing to stop you buying them later if you feel the need.
I only have the standard 3 piece DJI set, which so far has been enough for my needs, though I have thought about adding some polorising ones to my kit.
I've not used the Freewall ones, but hear good things about them here.
A lot of people keep asking "what filters do I need?" but it's impossilbe to answer properly without knowing the kind of work they intend to do. There are different filter for different jobs, no one size fits all answer. |
