DGpousson
Flight distance : 29062 ft
Johnnokomis Posted at 11-14 12:53
My only question is, why? It takes 3 seconds to unfold the arms. The included case is smaller, just as IP rated and can already hold enough batteries to last an entire day. I like the idea of charging the batteries while in the case but to point out the obvious issue you'll run into, that thing is going to heat up ridiculously fast. Not just the batteries but also the USB C charging adapter. That's going to be a fire hazard and kill the batteries lifespan. This doesn't seem like an advantage worth $400 and nearly a months wait. Just my opinion, let us know how it works once you receive it.
Also - I carry my batteries and chargers separate from the drone. I have run thru batteries on several jobs. I normally land at about 20% left on the battery.
I bring 8 batteries and a jackery - often recharging the RC as I fly. So, yes it is a pain to carry another case- I agree. Some of my map plans are almost 200 minutes. |
