Sam654
Flight distance : 132667 ft
djiuser_d3Bi7bZgYQga Posted at 11-18 07:47
I have a sony uhd blue ray that plays 4k 60 movies (unsure why they labeled it bluray) but there aren't many that are in 60fps. If anything, i guess i can use the sony to paly on tv.
Also, due to my ignorance, I learned that the M4P also has sd slot. I suppose the drone footage would be better due to raw video/pics vs dashboard on rc2, right? Or am I thinking about this wrong?
Typically you would put a Micro SD into the drone and it will record video and photos to that. That is the full quality footage you want.
The RC holds a cache which is not full quality, I think it's only for playback and review of shots on location.
Also handy if you lose the drone, as you may have a recording of what happened, as well as the flight logs.
So you take the SD from the drone, put that into a USB reader and plug that into the TV, which may or may not work.
I use a card reader to transfer to my PC, I find it less cumbersome than plugging the drone itself in. |
