Sean-bumble-bee
Flight distance : 15997 ft
Kopanz Posted at 11-18 06:18
They think that the middle shell is critically damaged and it's dangerous to use the drone in this condition. However nothing is loose on the drone and the drone isn't operating like it had any crash.
They say that currently the drone is out of warranty, when they send the photos of the drone to DJI for the warranty repair DJI will refuse warranty repair because it's damaged.
They even asked me for the flight records of the crash it had.
I would agree that the middle shell appears compromised and should be replaced but if you have not crashed it and assuming it is within the warranty period, then the replacement of the middle shell should be a warrant matter itself.
The replacement of the heat sink cover is, in terms of the work and time needed, a trivial matter, I would have thought the cost of the cover itself was minimal.
Besides, from memory, the heat sink cover MUST be removed in order to dismantle the drone and the complete dismantling of the drone is required when the middle shell is to be replaced ...... I.e. there is NO additional work involved in replacing the heat sink cover.
Have a look at Mavic Mini and or Mini 2 dismantling/teardown videos on youtube.
Do DJI themselves have offices in Turkey? If so I woud contact them directly.
Aside from questioning the delay in posting this thread, the only other thing I would question is the green smudges on the rear of the heat sink cover.
As for logs, if you have not crashed the drone and are telling them that the drone has not been crashed, then their request for logs seems a bit daft to me.
It would likely mean them trawling through however many .txt flight logs you have or sent them and, unless they have software that can read the encrypted flight logs. It's going to take some time to decrypt the logs and additional time to look through the decrypted files in an attempt to find a undeclared crash.
Since you have a recorded mileage, of 22.03 miles, you have obviously sync'ed logs with DJI at some point in the past, if those were FLY app logs then the DAT's on the screen device will have been deleted.
That leaves the DAT's on the drone and there is likely to be a limited number of those, perhaps 15 - 20, and they'd need software from DJI to decrypt those.
There is limited storage space available for storage of those DAT's on the drone so the old logs are over written ....... unless there is some storage space we dont know about.
As far as I know there is no way for them to know how many flights the drone has flown, so, as far as I know, you could send them 50 logs or 100 logs and say "that's all I have" and they can't prove otherwise .... unless you didn't send then a log that had been sync'ed and DJI released that log.
A screen device DAT's name includes a counter that counts the number of times the drone has been switched on but that is no guide to the number of flights flown. Some of my DAT's cover 3 or more flight, others cover zero flights. Screen device logs, both .DAT & .txt, are only recorded when the screen device is connected. If you use a phone as a screen device then you can in fly the drone without the phone connected to the controller and consequently no logs.
