DJI Gamora
Hi, there. Thank you for reaching out. The available camera parameters displayed on the DJI Fly app will be based on the aircraft specification. As the 48MP photo is to use a Medium Tele lens, please switch to a Medium Tele lens. Here is the way to trigger 48MP when using DJI Mavic 3 Pro:
method A:
1. choose 3x so as to use the Medium Tele lens;
2. Under PRO mode: click the photos parameter settings to 12MP and 48MP there below. Choose the resolution and aspect ratio, then start shooting.
method B:
2. Under AUTO mode: Click "...">Camera>48MP >settings the aspect ratio and the format and resolution there as below:
Kindly note that 48MP is not supported under Explore mode. I hope this information helps. Thank you for your support. |
