Rick.lai
Flight distance : 37333 ft
Singapore
IftiBashir Posted at 11-20 01:54
From what I can gather from your post, the actual item itself was fine - it was the charger that was at fault. Hence if you sent an item back and it turned out the said item was fine, and the issue was user error (in your case, your charger not working properly), then why would the business pick up any costs associated with it? Import tax is not something charged by DJI, its by your local authorities via the courier. DJI do not see a single penny of it.
In this case, should DJI refund you anything it would be a goodwill gesture, not because they have to.....
i can see your rationale on the matter. Here are other views,
1) had they sent a good working condition products, this would not have happened.
2) I am a first timer using Osmo Pocket 3; when it didn't work and i contacted the customer service, the customer service could have isolate that problem and suggested i test the OP3 fast charger....but didn't.
3) When i received the OP3, DJI had paid the import tax. This is an item sent back, repair, and sent back to customer. DJI should have known a double tax levied on the same item. After all, it began with a faulty product... that trigger this incident. |
