GergelyKiss
Flight distance : 3249649 ft
Hungary
Dear LV_Forestry,
Thank you, but this is also telling that what I told you - sorry, I am just an engineer and not a lawyer - , so apologies if I misunderstood something, but it looks like this to me:
Subcategory A1:
for unmanned aircraft referred to in point (5)(d), be conducted in such a way that a remote pilot of the unmanned aircraft does not overfly assemblies of people and reasonably expects that no uninvolved person will be overflown. In the event of unexpected overflight of uninvolved persons, the remote pilot shall reduce as much as possible the time during which the unmanned aircraft overflies those persons;
(5)
be performed with an unmanned aircraft that:
(d)
is marked as class C1 and complies with the requirements of that class, as defined in Part 2 of the Annex to Delegated Regulation (EU) 2019/945 and is operated with active and updated direct remote identification and geo-awareness systems.
Subcategory A2:
be conducted in such a way that the unmanned aircraft does not overfly uninvolved persons and the UAS operations take place at a safe horizontal distance of at least 30 metres from them; the remote pilot may reduce the horizontal safety distance down to a minimum of 5 metres from uninvolved persons when operating an unmanned aircraft with an active low speed mode function and after evaluation of the situation regarding:
(3)
be performed with an unmanned aircraft which is marked as class C2 and complies with the requirements of that class, as defined in Part 3 of the Annex to Delegated Regulation (EU) 2019/945, and is operated with active and updated direct remote identification and geo-awareness systems.
So, if I try to interpret the legal text, this can be the same as what the schematic shows that only a C2 drone can operate under A2 - close to people due to C2 has more strict regulations - as you mentioned - that C1 or C0. By the way, the only difference between C1 and C2 regulations is that sentence:
- they have a low-speed flight mode that can be activated by the pilot at any time, where the maximum horizontal speed is 3 m/s (except for fixed-wing UAs)
Many thanks and all the best,
Gergely
