dznyc
DJI Paladin Posted at 11-22 23:02
Hi there. Thank you for reaching out. Can you please tell us more about the issue you encounter when you connect the DJI Osmo Pocket 3 on your Mac using Skype? After you connect the device to your computer using a USB cable, the device will go into USB mode then tap Webcam to enter Webcam mode and the device will function as a webcam input device. The bottom of the screen displays a Webcam. Press the shutter/record button to start recording. Please note that if the computer software does not provide the option to select the camera or video source, it indicates that the software does not support the webcam functionality. Please keep us posted. Thank you.
Thank you for the response! Yes, I connect to a USB cable, and then I tap Webcam mode. Both Skype and Teams (and Camo) shows the Pocket 3 as a webcam video source, but when I select it, the screen goes black. I am, however, able to use it in Zoom and Google Meet.
Any help would be much appreciated, as I bought it primarily for webcam use and typically use Skype with the company I work for.
Thank you. |
