Operator Registration Number
5829 15 2023-11-22
GergelyKiss
Flight distance : 3249649 ft
Hungary
Dear All,
Could you please help me, how can I obtain my Operator Registration Number which is format like this : xxxxxxxxxxxxxxxxxxx-xxx ?
DJI Air 3 only accept characters in this format, however, I don't have any like that.
I have an A2 license number, which is: HUN-RP-6lro5j0gzz0t
I have the operator number which is: HUNyzhb9q1wsm271
Neither of my IDs not the same.
Many thanks and all the best,
Gergely
2023-11-22
djiuser_MgSStEXd9jDY
Flight distance : 98507 ft
Greece
If you go to your country's regulator and login, at the same place you found the second number, (without the dashes) there also should be a number which is exactly the same, only it also has the last 3 digits (which are private, and that's why they are not printed out)
It should be mentioned simply as "Registration Number"
2023-11-22
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. You may find the UAS Operator Registration Number on the DJI Fly app. Go to General settings (3dots)> Safety> RemoteID> UAS Remote Identification. Please make sure that the app version you are using is the latest one. Hope this helps. Thank you for your valued support.
2023-11-22
GergelyKiss
Hungary
Dear All,
Thank you All!
I know where should I type in this code, but my "Operator Code" is not in this format, so "djiuser_MgSStEXd9jDY" might have the correct answer.
Unfortunately, it is a little bit complicated in Hungary, because we do not have a homepage where I can log in to the official regulator.
We only receive an official letter once we fill out an official form with that number which I highlight above. (16 chars where the first 3 chars are the country identifier and after I have 13 chars.)
That is it, I cannot access any further or "secret code".
I wrote them an official letter to help me out with this format what DJI required and send me what code can I insert.
All the best,
Gergely
2023-11-22
PhantomDj
Greece
That's odd. Since your country is a member of EASA, it means that it complies with all EASA requirements.
The registration system is unified among member states of EASA. In plain words, you should get the same codes as I did, and your codes are the same within all country members of EASA.
It also means that each country's regulatory authority has access to those data.
It's true that my printed certificate had only the 13 numbers printed in it. But on the online portal of my local aviation authority I can see the two "registration numbers" that are identical, but one of them has the extra 3 digits.
So, you definitely have such a number (EASA requirement). It's just a matter of how to find it.
2023-11-23
hamzaajmi
Flight distance : 19980 ft
DJI Paladin Posted at 2023-11-22 21:03
Hello to all of you.
I'm in need of assistance!
I have my drone operator registration number from Norway and I have purchased a new DJI Air 3 from the United States. I registered my drone in US while I was living here.
Regretfully, though, I am unable to locate the DJI RC 2 option "UAS Remote Identification" where I would normally enter my Norwegian operator number. I've included screenshots, and my firmware is upto date.
1-3 14:53
DJI Paladin
hamzaajmi Posted at 1-3 14:53
Hi there. Thank you for reaching out. This function can only be enabled if you are inside the EU region. Hope this helps. Have a nice day ahead.
1-5 01:59
hamzaajmi
DJI Paladin Posted at 1-5 01:59
thank you  Paladin,
1-6 16:33
DJI Paladin
hamzaajmi Posted at 1-6 16:33
thank you  Paladin,
You are very much welcome. Feel free to contact us if you have other inquiries. Thank you for your valued support.
1-8 02:26
djiuser_NhNZYQkb4oqJ
Flight distance : 259239 ft
Portugal
Hi Paladin,
I finally received my operator ID and when I go to settings (3dots)> Safety> there is no place to enter it as per the photo above. The UAS Remote Identification isn't showing and I'm in Europe.
TIA
1-8 11:19
DJI Paladin
djiuser_NhNZYQkb4oqJ Posted at 1-8 11:19
Hi Paladin,
TIA
Hi there. We do apologize for the trouble that this has caused. Kindly please try to reinstall the DJI Fly app on your mobile device if you are using a remote controller without a built-in screen. Also, we highly recommend updating the firmware of both aircraft and remote controller via DJI Assistant 2 software on your computer. Please keep us posted. Thank you.
https://www.dji.com/downloads/so ... sumer-drones-series
1-9 23:00
fans40111990
Flight distance : 46283 ft
Belgium
Hello,
I’m using my Dji mini 4 pro drone with rc2 controller (i.e. with build in screen) in Belgium (EU), installed all (until today) updates/upgrades for both uas and controller: no indication/possibility of operator-id !
PS and i need this remote -id /operator-id info for flying in a VLL2 zone…
1-14 02:12
Lambros Lambrou
Cyprus
Hi all, I have flown to Cyprus from the UK. Have a EASA operators number and have a licence. As soon as I try to input the first letter of the Operator ID no in the appropriate box of the UAS Remote Identification field it gives me the error message "Registration Format Error" as per the attached. Even when I input the full details .. same error. Any ideas? Thanks L
1-19 02:28
0gener
Portugal
Hey,
I am in the same situation, I have a DJI Mini 4 Pro with the RC2 controller in Portugal. I updated the firmware of both the aircraft and the controller using the DJI Assistant 2, but this option still doesn't show up in the settings.
Aircraft Firmware: 01.00.0300
RC Firmware: 02.00.0500
1-31 09:49
Andreja
Flight distance : 1085302 ft
0gener Posted at 1-31 09:49
Hey,
Mini 4 Pro is a C0 class drone, which means that it doesn't transmit operator ID, so there's no way to enter it.
1-31 15:52
gba
Austria
Hi Paladin,
TIA
Hi!
Did you find how to fill in the number?
If not, support has advised me to have a good GPS signal to be able to find the Remote ID item.
As soon as the AIR 3 had a white GPS symbol, the Remote ID item appeared in the Security tab.
Hope this helps.
Kind regards,
Gerald
2-7 04:25
