duncan.lamb
Funny that, in my experience even when it hits critical level, if you keep playing with the controls the Phantom will not auto land, but will keep flying until it drops (literally). Admittedly mine was in GPS mode when I did this little test. However I tested again in Naza mode, and initially when the first low battery threshold is reached and the lights start flashing red you momentarily lose control and the Phantom will start to initiate auto-land or RTH (depending on what you've configured in the assistant software), but if you keep using the sticks you can then regain control and keep flying, even through the critical battery level (until it drops, as I say - not recommended, obviously). Strange, because I didn't really get a clear-cut response when I asked this question, and your experience tends to suggest that you're seeing the opposite, in other words the behaviour that I had expected when I did my little test until the Phantom simply shut off and then dropped to the ground - only 50cm up, thankfully. So from my experience, unless you relinquish control, regardless of the low battery threshold reached, you can fly the Phantom into the ground (if you're so inclined/insane!). |
