Minimum operating temp
760 1 2023-11-26
eerikoo
Norway
Hi,
Action 2 is a fantastic camera, but why does the user manual say minimum operating temp is 0°C / 32°F?
This makes no sense for an action camera, especially if you live in the northern hemisphere. Anyone else ignoring this? I will use it only with the power module attached, and the camera module at full battery.
2023-11-26
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Yes, DJI Osmo Action 2 is designed to have an Operating Temperature of 0° to 40° Celcius (32° to 104° Fahrenheit). You may check the DJI Osmo Action 4 as it features a freeze-resistant battery design that helps you operate in low-temperature environments in high performance while you can record up to 150min recording in temperatures as low as -20°C (-4°F). For more information, you may visit our website at https://www.dji.com/global/osmo-action-4 . Thank you for your valued support.
2023-11-27
