EnjoyUrLifeTV
Flight distance : 122375 ft
Thank you both. My questions were only partly answered, tho.
#1 So I always have to turn on/off receiver AND mic, meaning 6 times a button pressed for every clip at minimum?
#2 Are you saying Paladin, that turning on the cam and then hitting record is better than using the "Auto record" function? I cant make sense of your reply really. That would be a minimum of 8 times a button pressed then.
#4 Would it maybe be better to just leave mic/receiver on? Considering that I will make clips in a time frame of lets say 10-12 hours (mainly idle, short clip here and there), will the batteries last that long?
#5 Does the receiver charge when plugged to the cam? If so, does that also work while connecting via a cable? Which cable is recommended then, if not included?
I am a bit mindblown that THE most logical combo, cam with mics, both DJI, dont work together better. |
