Mavic Pro 2
245 2 2023-12-11
rjvickery
New Zealand
My drone has developed a issue with the front sensor and I have to recalbrate the drone. However I can't download the required programme version due to the age of the drone (over 4 years old) and that I'm usinng Sanoma (imac and ipad pro). Any suggestions on how to calibrate the drone?
2023-12-11
DJI Paladin
Flight distance : 318 ft
Hi there. We do apologize for the trouble. Can you please confirm if the unit experienced a hard landing before? You may need to download the DJI Assistant 2 software on your computer using the link below to calibrate the vision sensor on your DJI Mavic 2 Pro. I will also post a tutorial video wherein you can follow the steps to properly calibrate your sensor. Please keep us posted. Thank you.
DJI Assistant 2 software: https://www.dji.com/downloads/softwares/assistant-dji-2-for-mavic
2023-12-11
rjvickery
New Zealand
This is the message I get when I go to the page you suggested
DJI Assistant 2 For Mavic
Compatible with Mavic.DJI Assistant 2 is not currently compatible with macOS version 11 or later. This issue will be resolved in a future update.
I have MacOS 14.2 and therefore the programme won't load correctly.
I don't believe there was a hard landing or a knock to the drone.
Russell
2023-12-11
