hillbillyflyer
Flight distance : 360505 ft
Dirty Bird Posted at 12-16 13:13
Regarding the LEDs for FLIGHT BATTERIES of all models in the Mini series, when charging is complete & the batteries are full, ALL LEDs are lit solid. They remain lit until you remove the battery from the charger or remove power from the charger. This is true whether you charge them in the aircraft or in the DJI charging hub.
The RCs are different depending on the model. The old style RCs where the phone mounts underneath will also leave the LEDs solid lit when the battery is full. The newer RCs where phone mounts above, or the DJI RC/RC2 with built-in screens, the LEDs turn off completely when charging has completed.
Very good to know. They should make it more clear in the manual or possibly even correct the manual. Page 65 of the mini 4 pro manual.
Using a Charger
1.Ensure the battery has been correctly installed in the aircraft.
2.Connect a charger to an AC power supply (100-240 V, 50/60 Hz; use a power adapter if
necessary).
3.Connect the charger to the charging port on the aircraft using a USB-C cable.
4.The battery level LEDs display the current battery level during charging.
5.The Intelligent Flight Battery is fully charged when all the battery level LEDs are off. Detach
the charger when the battery is fully charged |
