Blank the Pocket 3 screen when connected to the Mimo app?
2073 6 2023-12-18
3dbproductions
Flight distance : 1723471 ft
Hello,
On the Pocket 2, when I connected to the Mimo app on my iPhone (via WiFi), the Pocket 2 screen went blank.  Which I liked because it improved the battery life on the Pocket 2.
On the Pocket 3, the screen remains on when connected to the Mimo app.  Is there a setting I am missing that blanks the screen on the Pocket 3 when connected to the Mimo App?  If not, what is the reasoning to leave the screen enabled to just drain the battery?
Thanks!
2023-12-18
DAFlys
You can enable the screen to blank when you are recoding after x minutes.    It's in settings when you swipe down.
2023-12-19
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. Regretfully, we don't have an option on either the product or in the app to set the screen off time. However, you can set the "scrn off when rec" function to 3s, and when the unit starts to record, the screen on the DJI Osmo Pocket 3 will off after 3s. Furthermore, the screen will turn off automatically after around one minute of inactivity. Hope this helps. We appreciate your understanding.
2023-12-19
fansfe82067d
That's odd.  I thought mine went blank when connected to Mimo.  Must look more closely!
2023-12-19
fans71d2c512
DJI Paladin Posted at 2023-12-19 03:43
Hi, just wondering if you know when the screen goes off after inactivity will the pocket 3 remain connected to my phone so I can start recording when needed?
2024-4-14
DJI Paladin
fans71d2c512 Posted at 4-14 06:29
Hi there. Thank you for reaching out. We may need to forward this to our relevant team for further clarification. We will keep you posted. We appreciate your patience.
2024-4-14
DJI Paladin
Hi there. Thank you for patiently waiting. Upon further review, the DJI Osmo Pocket 3 won't power off and just turns off the screen and that will not disconnect with the DJI Mimo app. You can test it and check if the phone will not disconnect during the screen off. Hope this helps.
2024-4-18
